LabWindows/CVI
TCP using LabWindow/CVI ? ?
Hi !
I'm looking for ways to learn & use "TCP" communication ( Client /
Server ) together with LabWindows/CVI.
( all examples at your site are for LabView only )
Can you please let me know where to find an TCP Client / Server
applications examples for LabWindows/CVI ??
If posible i'll like the exact addresse of pages contains this
examples/information !
Also if posible i like to know if there is something about Ethernet or /
and Lan ( Local Area Network ) in the LabWindows/CVI.
I want to add that i know about the TCP Client/Server example in the
LabWindow/CVI - Samples, but it is not complete - it is only a skeleton
which not explain
it all.
I also want to know about the hardware i need to establishes a TCP
connection !!
Which cable should i use to connect the Server & Client computers ?
Where exactly should i connect the cable in the computer ?
It very importent for me to get full answer as soon.
Thank you very much !!
Regards
Noam G.
(3,831 Views)
I would also like to see these examples, but I can help you on some of this. You don't really need any hardware (since you are accessing this site, I assume you have an ethernet card). For a cable, if you are connecting both computers to a LAN or the internet (direct or via a hub) use a RJ-45 ethernet cable. If you are connecting the computers directly to each other, you must use an ethernet crossover cable. The cables just connect into your ethernet port (where your internet access is plugged into now).
Go here for more info on a crossover cable:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/38528df7b4d1feae86256dcf0069b14d?OpenDocument
Derek
(3,831 Views)
