LabWindows/CVI
TDMS C DLL can be used in a VB Project?
Hello
We have a project in vb that uses measurement information kept in an excel file.
Now we want to use this information along with information contained in a TDMS file.
I've tried using the TDM C DLL  provided in http://ni.intellisurvey.com/run/2007codelicenseagree, unsuccesfully.
When I try to add the reference to the .dll, this error pops out:
"Cannot add the reference to "/filepath/nilibdcc.dll. Make it sure you can access the component or  it's a valid COM component"
(The message is a translation from spanish)
What i'm doing wrong? It's possible to use it?
(3,775 Views)
Accepted by topic author Tomacco
Hi Tomacco,
the TDM-C-DLL was designed to access TDM(S) files using C.
Otherwise it is possible to access DLLs from vb. Please refer to this article: http://support.microsoft.com/kb/106553. But I havn't tried this for the TDM-C-DLL.
Another option is to use Measurement Studio if you want to access TDMS from within VB.
Stefan
(3,772 Views)
Thanks!
The Measurement Studio option looks far more simple, so I will try it.
(3,730 Views)
