LabWindows/CVI
TDMS ChannelGroup / Channel Properties user defined
using the TDMS Library (CVI 9.0) i'm creating a tdms file at runtime. On
importing this file in excel, first work sheet shows the properties of the
file, the channel group and the channels.
How can i add more information to this work sheet? F.e. i need to add
calibration information of each sensor (channel), something like date of
last calibration, calibration val_1, calibration val_2.
Also i want to fill out the fields for Minimum and Maximum (Channel), Start
Index, average value.....
I didn't find a function in the library to add user defined properties, how
can i do this ?
Norbert Rieper
Bremerhaven
Germany
(3,332 Views)
i found out that could uis the function TDMS_SetChannelGroupProperty and
TDMS_SetChannelProperty with user defined property strings. On the first
look i thought that only the use of the predefined property strings is
possible an didn't see the "" option.
But now i have an new question.......
Is it possible to determin at which position (line) the user defined
properties appear in the file, f.e. i think its a good idea to align my
strings as follows:
Sensor 1 Cal date: 12.05.08 Cal val: 1.0234
Sensor 2 Cal date: 30.06.08 Cal val: 1.056
Sensor 3 Cal date: 02.05.08 Cal val: 1.9876
Norbert Rieper
"Norbert Rieper" <nrieper@isitec.de> schrieb im Newsbeitrag
news:493e2040@PYROS.natinst.com...
> Hello,
> Start Index, average value.....
> how can i do this ?
> Norbert Rieper
> Bremerhaven
> Germany
(3,329 Views)
