LabWindows/CVI
TIMER STOP AFTER FEW SECONDS
  • Hi to all of you. I want to know that when timer start how can we set that after three seconds timer starts automaticaly.  means how can i count  three seconds basicly and disable the timer after three seconds
(2,441 Views)
Hello!
I'm a bit confused by your question, but I'd say you can look into a couple different options:
Hope this helps!
R Dahlman
(2,413 Views)
sory sir  yes my question was confusing. sir actualy i have a task in which i have to transmit some data to other source and in reply there will be response. after its response i will again transmit some data. one critical part of task is that if after 3 seconds if there is no reply from other end i have to stop transmit data. i m confused that how will i wait for 3 seconds and how would i know that there is no reply during 3 seconds
(2,409 Views)
How are you transmitting your data and what are you sending it to? A lot of times there is timeout functionality built in to device communication APIs that we can use more easily!
(2,401 Views)
