LabWindows/CVI
TS_PropertySetValNumber Options
I am using GetCtrlIndex() to obtain the index of selected value in ring control. Need to set fileglobal with the value of index. TS_PropertySetValNumber() takes double, is there any other function or options to set the varaible with index value?
int *selectedTestIndex = 0;
switch (event)
case EVENT_COMMIT:
GetCtrlIndex(gMainWindow.statPanelTab,control,selectedTestIndex);
tsErrChk(TS_PropertySetValNumber(TSSeqContext, &errorInfo, "FileGlobals.Monitor.TestSelection", 0, selectedTestIndex));  //this takes double and errors out with selectedTestIndex, need to set the varaible with index value of ring control.
TIA.
CLD
(3,909 Views)
Accepted by topic author lvrat
Don't believe options would work so modified the definition:
int selectedTestIndex = 0;
GetCtrlIndex(gMainWindow.statPanelTab,control,&selectedTestIndex);
CLD
(3,906 Views)
