LabWindows/CVI
TSQ callback not called
I am currently migrating a project to CVI 9.0 which worked fine with the last version (was it 8.5?)
Now i am facing some trouble with thread safe queues.
I am (according to the return code, successfully) installing a TSQ callback with CmtInstallTSQCallback, where I pass the name of my CVICALLBACK callback function. The callback was intended to read items from the tsq, while data is written asynchronously to it. This writing happens at quite a low frequency, and there is a processSystemEvents() in the main function of the same thread, which is actually called.
Now the problem is that the callback is never executed, so the TSQ runs into an overflow quickly. I don't know if I am missing something, are there any major changes to thread-safe queues in the new CVI version?
If it helps - I am working on a PXI 8196 RT target with LV RT 8.6 and the CVI runtime engine and CVI network variable engine or RT 9.0 installed.
Any help is greatly appreciated!
(3,809 Views)
Accepted by topic author cholulteca
I think I might have found the answer myself, there is a bug in CVI 9.0 which has to be fixed manually - see http://digital.ni.com/public.nsf/allkb/44C0C08DAE15E4FD8625756300564305 for further information.
(3,800 Views)
