LabWindows/CVI
Table action on enter key
When editing a string cell in a table, is it possible to make the enter
key move to the next column rather than the nest row and remain in edit
mode?
John Cameron.
(3,572 Views)
In message <36lvQlDH0s$$EAIQ@ob5.co.uk>, John Cameron
writes
>Hi,
>mode?
Sorry, I should have said version 6.
John Cameron.
(3,572 Views)
Yes, you can do this fairly easily. All you have to do is catch the KEYPRESS event in the table's callback, and then change the active cell yourself, taking care to "swallow" the original event. The following code should do the trick:
case EVENT_KEYPRESS:
GetCtrlAttribute (panel, control, ATTR_TABLE_RUN_STATE, &state);
if (state == VAL_EDIT_STATE)
keyCode = GetKeyPressEventVirtualKey (eventData2);
if (keyCode == VAL_ENTER_VKEY)
GetActiveTableCell (panel, control, &cell);
GetNumTableColumns (panel, control, &numColumns);
if (cell.x < numColumns)
cell.x++;
SetActiveTableCell (panel, control, cell);
S
etCtrlAttribute (panel, control, ATTR_TABLE_RUN_STATE, VAL_EDIT_STATE);
return 1;
break;
Luis
NI
(3,569 Views)
In message <506500000005000000D64B0100-1073519706000@exchange.ni.com>,
LuisG writes
> cell.x++;
> SetCtrlAttribute (panel, control,
> return 1;
> break;
>Luis
>NI
That worked. Thanks Luis.
John Cameron.
(3,569 Views)
