LabWindows/CVI
Ternimate a thread.
Using the Windows' named pipe to communicate between the two applications, the main function code phase is like this:
static HANDLE pipe_rcvDB; /*pipe handle*/
static HANDLE hPipeEvent;/*pipe event handle*/
int main()
    pipe_rcvDB = CreateNamedPipe(DB2HMI_PIPE, PIPE_ACCESS_DUPLEX|FILE_FLAG_OVERLAPPED, PIPE_TYPE_BYTE|PIPE_READMODE_BYTE|PIPE_WAIT,
        1,1024, 1024, 1000, NULL);
    hPipeEvent = CreateEvent(NULL, FALSE, FALSE, NULL);/*Create the overlapped I/O event*/
    CmtNewThreadPool(2, &thdDBServerHandle);
    /*Spawn the thread to listen the message from the pipe*/
    thdStatus = CmtScheduleThreadPoolFunctionAdv(thdDBServerHandle, MonitorDBServerData, NULL, THREAD_PRIORITY_NORMAL, NULL,
                                    EVENT_TP_THREAD_FUNCTION_BEGIN, NULL, station_thdID = CmtGetCurrentThreadID(), &pipeMonitorTHD_ID);
/*The pipe msg listen thread*/
int CVICALLBACK MonitorDBServerData(void *functionData)
    DWORD nReadByte = 0;
    DWORD dwByte = 0;
    OVERLAPPED OverlapStruct;
    size_t status;
    memset(&OverlapStruct, 0, sizeof(OVERLAPPED));
    OverlapStruct.hEvent = hPipeEvent;
    while (TRUE)
        ProcessSystemEvents();
        ConnectNamedPipe(pipe_rcvDB, &OverlapStruct);
        WaitForSingleObject(hPipeEvent, INFINITE);
        /*check if there is a signal to finish the thread*/
        if (!GetOverlappedResult(pipe_rcvDB, &OverlapStruct, &dwByte, TRUE))
            break;
   }/*end of while loop*/
/*The call back of quit the application */
int CVICALLBACK QuitApplication(int panelHandle, int controlID, int event, void *callbackData, int eventData1, int eventData2)
    if (event == EVENT_COMMIT)
          SetEvent(hPipeEvent); /*Trigger the overlapped to stop the listen thread*/
          CmtWaitForThreadPoolFunctionCompletion(thdDBServerHandle, pipeMonitorTHD_ID, OPT_TP_PROCESS_EVENTS_WHILE_WAITING);
          CloseHandle(pipe_rcvDB);
          CmtDiscardTSQ(tsqHandle);
          CmtDiscardThreadPool(thdDBServerHandle);
          DiscardPanel(dataEditPanel);
When pressing the quit button, and by using the Windows API, the SetEvent() to trigger a signal for the thread, the thread can not received the signal, I hope the function GetOverlappedResult() in the thread can receive the signal, but it has no any response. Does CVI support the API?
David
(3,959 Views)
Hi David,
Yes, LabWindows/CVI does support this API. You can search LabWindows/CVI Help for detailed information. Hope this helps.
Xiaojian Wang
(3,931 Views)
Um, but why the SetEvent() can not trigger the GetOverlappedResult() and make a terminating event.
David
(3,926 Views)
