LabWindows/CVI
Test NI cDAQ-9188 using LabWindows/CVI
I am looking for help to create test for cDAQ-9188 with DIO and AIO modules.
Would you please advise with information as follow:
1. Adding device driver to a project.
2. Sample of UI.
3. Sample of test script for DO (AO) control.
4. Sample of test script for DI (AI) acquisition.
Thank you.
Sincerely,
Sam.
sdimalsky@sbcglobal.net.
(4,026 Views)
There is a tutorial on using DAQmx with LabWindows/CVI here: https://www.ni.com/en/support/documentation/supplemental/06/using-ni-daqmx-in-labwindows-cvi.html. That is probably a good place to start.
As far as examples go, there are several text-based examples (as long as you have DAQmx installed) located at: Start Menu >> All Programs >> National Instruments >> NI-DAQ >> Text-based Code Support >> ANSI C Examples.
(3,998 Views)
Aaron,
 Thank you for your advise.
Best wishes,
Sam.
(3,995 Views)
