LabWindows/CVI
Testing Code
Hi Al S I got A question. Im testing one of the comports on my computer to the loop back test with my code, onces it reads the data the code stops on the standard I/o
screen. Do you have any ideal why?
Also I have a LED indicator and for some reason its not changing colors when im doing my loop back test. I have debug it. but its not seeming to work for some reason.
could i get some assistance.
Im also receiving a NON-FATAL RUN-TIME ERROR:   "chiller.c", line 320, col 30, thread id 0x00001460:   Library function error (return value == -99 [0xffffff9d]). I/O operation timed out
you will see in the attachment below
(4,440 Views)
Darnell:
Your post did not include the file which generated the error: chiller.c
(4,430 Views)
ok i reposted
(4,420 Views)
ok SKIP MESSAGE THREE,  I FIX THAT PROBLEM. MY NEXT THAT I ENCOUNTER IS ON MY GUI I HAVE A SET POINT, BASICALLY IM TRYING TO ENTER THE TEMPERATURE
AND AFTER I ENTER THE TEMPERATURE I WANT THE TEMP TO DISPLAY ALONG WITH MY SP=\r.  remember im trying to set the temp to the instument.
so from my gui when i enter in the temp ,in my printf statement it suppose to print temperature i enter along with SP=\r.
you will see in the attachment. im just doing the loopbacl right now before get to the instrument.
(4,414 Views)
(4,413 Views)
AL S i complish it last nite , i had to put in some time last nite and just break everything down.
I have it to where if i enter a number from the gui it will return SP=(any number i set).
my question is ,is this the way to do it where in i should get a response back. is the instrument going to recognize how i got i
got set up ?is this the correct below. just need a little assistance.
//CopyString (tbox_read_data, 0, send_data, 0, temp_setting);
// printf("%s=%d",tbox_read_data,temp_setting);
         int TEMP_SETTING (int in,int out)
int b ;
int temp_setting=0;  //atoi(send_data);
char send_data[1000]={0};
             OpenComConfig (1, "COM4", baudrate, parity, databits, stopbits, inputq, outputq); //RS232 CMD
            GetCtrlVal (chiller, in, &temp_setting);
            //send_data[temp_setting]='\r';
            //temp_setting=StringLength(send_data);
            strcat(send_data,"\r");
            bytes_sent=ComWrt(1,"SP=",4);
             bytes_read = ComRd (1, send_data, 4);
                  if (bytes_read<0)
                    bytes_read=temp_setting;
           printf("%s""%d",tbox_read_data,temp_setting);
            //break;
            //case EVENT_RIGHT_CLICK:
    return 0;
(4,393 Views)
