LabWindows/CVI
Text with trademark sign
I was using the trademark sign (™ obtained with Alt+0153) in a string that I displayed on my panel title bar (CVI 7.0 and Win2000).
The problem is that this doesn't work on Win98 (there a square is displayed instead). I also not sure that this would work on a chinese or japanese operating system version.
Could someone help having this TM sign/symbol wotking on the different windows versions since Win95?
(3,267 Views)
Hello Rac,
Regarding WindowXP, I was able to use the TM symbol in the panel title by using Alt-0153.  This should also work on Windows 98, since it use the same character map.  What you could try is to open up Character Map (Start >> Accessories >> System Tools).  Choose the TM symbol, select Copy.  Then in the Edit Panel dialog window in CVI, press Ctrl-V.  Does the TM symbol now appear?
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
(3,252 Views)
Hello Wendy,
I remarked yesterday that the TM sign appear when I write it directly on a panel, but as I want to set it with a variable (my Text has to change dynamically), it fails.
(3,243 Views)
Hello Rac,
Sorry for misunderstanding your previous post.  Even when I use the SetPanelAttribute function with ATTR_TITLE to change the title of the panel to include the TM sign, I still see the correct behavior on Windows XP SP2.
SetPanelAttribute (panelHandle, ATTR_TITLE, "Title Test™");
Wendy L
(3,228 Views)
