LabWindows/CVI
Textbox text scrolls outside visible area
I am reading ASCII data from the comport and displaying it in a textbox. It scrolls and even the most recent response is not visible. How do I correct this?
(3,690 Views)
I am attaching a simple project that writes lines to a textbox and always displays the last line written: it may be helpful for your needs.
Roberto
(3,682 Views)
An easier solution is to use SetCtrlVal (panel, control, string);  to add lines at the end of the text box. This causes the box to automatically scroll to display the last line.
JR
(3,679 Views)
JR
Right and simpler Smiley Wink, but don't forget in this case to terminate the string with a "\n" to separate lines, otherwise the text will be added on the same line.
(3,677 Views)
...Unless the text box is set to 'Word' Wrap Mode Smiley Tongue
JR
(3,672 Views)
