LabWindows/CVI
The ActiveX controler gives me a hard time.
Hi.
I alredy put this question on the forum but a didn't get the answer so I will try to be more explicit.
I want to use 2 ActiveX controls: first when I create the calendar control and the second when I create an Excel control.
It doesn't mahters what control I create first, the second one fails to be created due to an error that apairs at the opening:
"ActiveX control error"
So I tried to use, before creating the second controler, this functions:
status = DiscardCtrl (My_handle, calendar);
CA_DiscardObjHandle (*objHandle);
because I was thinking that I must eliminate from memory the first ActiveX control, before I create the second one.
This solution doesn't work.
I put an example of what I try to
do. Press the Open Excel button before presing the Open Calendar button and you will see the error.
Thanks.
(2,903 Views)
you can find the anwere here
(2,902 Views)
