LabWindows/CVI
The CVI 7.0 didn't start correctly ? Help!
Today, when I start the CVI, it shows the message:
"   the requested feature on localhost has been activated for a computer,or you have recently
changed hardware in your computer.Please reactivate your license. "
than I reactivate your license ,but it didn't work.
I didn't change the hardware, what is wrong with it ?
(2,972 Views)
Hi Susan
I'm sorry to be the bearer of bad news but I believe that this problem is usually caused by corruption to one of the NI component drivers or software.
The general solution to this problem seems to be to completely uninstall then re-install any NI components that your running, you may only need to reinstall CVI though.
Could you try reinstalling CVI and it's runtimes? If this isn't successful then please provide your system report from MAX so that I can identify your specific setup.
Kind Regards
Chris | Applications Engineer NIUK
(2,967 Views)
