LabWindows/CVI
The DLL version does not match the import library for SQL Function CA_VariantConvertToType
I upgraded from Lab Windows/CVI v6.0 to v8.0. I used an example from the Lab Windows/CVI SQL Toolkit Reference Manual that contained the function “CA_VariantConvertToType" which did not display a NON-FATAL RUN TIME ERROR when the debug executable ran under v6.0. LabWindows/CVI v8.0 now shows the following message;
NON-FATAL RUN-TIME ERROR:   "main.c", line 2424, col 5, thread id 0x00000D18:   Function CA_VariantConvertToType: (return value == -2147220983 [0x80040209]). The DLL version does not match the import library
(3,646 Views)
Additional information gained.
By right-clicking on the function “CA_VariantConvertToType” and selecting "Go to definition" I discovered that this function's header file is "cviauto.h" and the file is located in "C:\Program Files\National Instruments\CVI80\include".
From there I located the library file "cviauto.lib" in "C:\Program Files\National Instruments\CVI80\extlib".
I then located the DLL file (cviauto.dll) in "C:\WINDOWS\system32".
All these files have the same creation date and time.
I found that CVI 8.0 "OPTIONS/ENVIRONMENT/Include Paths..." has the header path for the "cviauto.h" file.
Why does CVI 8.0 generate the error?
And,
My program runs an Oracle stored procedure with 5 parameters consisting of INPUTS 1-3 and OUTPUTS 4&5 . Running my program results in all inputs correctly entered into the database. OUTPUTS are the concern.
I do get results stored in the VARIANTS "&value4" and "&value5" below;
    /* Examine the parameter values */
DBGetParamAttribute (hstmt, 4, ATTR_DB_PARAM_VALUE, &value4);
DBGetParamAttribute (hstmt, 5, ATTR_DB_PARAM_VALUE, &value5);
value4 results in the following;
NAME             VALUE                 TYPE
value4         VT_BSTR; "0"         VARIANT
value4.n1   0x00461668        union {struct_tagVARIANT n2;DECIMAL decVal;}
How do I get this information into a C-code string array variable?
(3,598 Views)
