LabWindows/CVI
The SetTableCellRangeVals function
Hi.
I am trying to use the SetTableCellRangeVals function.
My array has only strings and the table cells from my range, have the same type.
char Array[20000][7]={0};
InsertTableRows (My_handle, Even_TABLE, -1, Number,AL_USE_MASTER_CELL_TYPE);
SetTableCellRangeVals (My_handle, Even_TABLE,MakeRect (1, 2, Number, 1), &Array,VAL_COLUMN_MAJOR);
Where did I make the mistake?
Thanks.
(3,463 Views)
Try this..
char *Array[2000] = {"Hello", "my", "name", "is", "Foo"};
InsertTableRows (panelHandle, PANEL_TABLE, -1, Number, VAL_USE_MASTER_CELL_TYPE);
SetTableCellRangeVals(panelHandle, PANEL_TABLE, MakeRect(1,2,Number,1), Array, VAL_COLUMN_MAJOR);
Jeremy L.
(3,443 Views)
