LabWindows/CVI
The callback function specified in the UIR file, is not a known function
I'm compiling a Code::Bloks project with C and FORTRAN source files using "x86_64-w64-mingw32-gcc-8.1.0.exe" as a compiler on a Windows 64bit system.
The project includes a UIR generated with CVI2019 and for this reason I used the external compiler support for generate the table of callback functions C file that I included in the project.
Compilation and linking seems going well and an exacutable file is produced.
However, when I run it, I get the following error in call to LoadPanel function:
Error code -86, The callback function, XYZ, specified in the UIR file, is not a known function.
Obviously the callback XYZ is defined in the project.
I tried to and the linker option -rdynamic, but this is not supported by the compiler "x86_64-w64-mingw32-gcc-8.1.0.exe".
Could someone be of some help?
Thank yuo very much.
Lorenzo
Message 1 of 1
(2,379 Views)
