LabWindows/CVI
The format of file in newer than this version of CVI Runtime error-114 UIEFileFormatIsTooNew
On my Windows 10 system my CVi application throws the error above at startup.
Other users in my office have no problems running the exact same version of the application with the exact same version of the CVI runtime on Windows 10.
I have the application running properly on several Windows 7 systems.
I have tried 2010,  2015, and 2017 runtimes.
After some combination of installs and uninstalls of the runtimes and the application, the application started working correctly
Then my disk crashed, and after restoring every thing, I'm getting the same runtime error again.
We have customer systems running Windows 10 and this application and this problem has never been encountered on a customer system.
It seems to be specific to my Windows 10 system. But starting from a fresh Windows 10 installation didn't seem to have any affect on the problem.
Anyone have any ideas as to what might be going wrong?
(3,062 Views)
What version of CVI and Operating System are you building on?
Does your application have any dependencies on other NI drivers (I.e. DAQmx, VISA, etc.)?
Dane S.
Product Support Engineer
(3,032 Views)
I am using CVI 9.0.  I am building on Windows7.  The application depends on VISA.
I decided to rebuild and after installing using the re-built distribution kit everything works fine.
I'm not sure what the problem was, but I'm moving on.
Thanks for your response.
(3,024 Views)
