LabWindows/CVI
The label of a table
Hi.
In my project I use a table witch appends data from a file. After appending the data into the table the label of the table changes into the path of the file that I used. I need my label to remain unchanged. How can I do this?
Thanks.
(2,900 Views)
What is your table? A CVI table control? An Excel spreadsheet or SQL table opened using ActiveX?
What label are you talking about?
What functions do you use to append data from a file to the table?
A CVI table control has no direct connection to the file from which you read the data. Its label does not change automatically, but it can be changed by SetCtrlAttribute().
(2,893 Views)
