LabWindows/CVI
The program Excel don't start from CVI.
Hi.
I tried to open the program Excel from my CVI aplication.
I have used the function:
error = Excel_NewApp (NULL, 1, LOCALE_NEUTRAL, 0, &ExcelAppHandle);
I think that my problem apairs when I use the Calendar object (I create an ActiveX object using MSCAL functions) and after that I try to open Excel.
If I try to open Excel before using the MSCAL functions, Excel opens whithout a problem.
I tried to use the function:
CA_DiscardObjHandle (*objHandle);
but this has no efect.
Thanks.
(3,226 Views)
What's the error message you get back? Did you remember to register the activeX control by using the following command "regsvr32 mscal.ocx"?
(3,226 Views)
I don't know much about ActiveX but maybe it works when you start Excell with CreateProcess( ) (from WindowsSDK) first ?
(3,226 Views)
