LabWindows/CVI
The program has caused a 'General Protection' fault
Does anyone run into this kind of problem "The program has caused a 'General Protection' fault at 001B:FF0CFF0C when I choose to resize or maximize my main GUI. My project *.exe size is more than 7M
Anyhelp would be very appreciated. Thanks 😞
(4,191 Views)
Thieny,
What version of CVI are you using?  I've never run into this issue before personally, can you provide any code that demonstrates the problem?
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
(4,174 Views)
Snowman,
I'm using LabWindow CVI 9.0 and my program is very large. The problem happened when it call RunUserInterface ()
I can run this program on LabWindow CVI 8.0 with no problem of resize or maximize.
(4,166 Views)
Is your exact version 9.0.0.330 ? If so you need to upgrade, if not...then I would still like an example program.
(4,159 Views)
