LabWindows/CVI
The straight squares generated by VAL_VERTICAL_BAR in plotxy, can the distance between the two straight squares be modified
我希望能让两个直方间的距离可以更靠近一些
(1,377 Views)
Accepted by topic author 232356
Do you have a screenshot of what you are trying to achieve ?
(1,319 Views)
  • Thanks, I've solved the problem by using rectangles
(1,311 Views)
