LabWindows/CVI
The use of "MS Office Web Component 9.0" (MS Office woorksheet ctrl) in LabWindows/CVI ?
I would like to retrieve and modify data in a workspace using a "MS Office woorksheet" (MSOWC.dll) control panel.
The instrument (MS Office Web Component 9.0) has been generated but I don't find the functions that can display and store data.
I am working with LabWindows/CVI in "Windows2000 Pro".
Thank you for your aswers...
(2,983 Views)
Hello
The CVI Controller wizard seems to have generated all the methods and properties associated with this control. You might want to check out some examples for this control to give you an idea of how to set this control up correctly. Check out this link to get started. You might also want to check out the paragraph marked Important which indicates that these controls only work in IE, since these are web controls. So im not sure if they will work on a CVI panel.
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(2,983 Views)
