LabWindows/CVI
There is no VISA installer in the BUILD section of the LVProject. I looked in the widget "Additional Installers" under "My Installer Properties". How can we be sure VISA is installed on a system (ie visa32.dll ).
We have a couple of PCs that don't have visa32.dll installed and we finally used "visa502full.exe" to get this done and it works. But our "clients" may not have visa installed, and I wondered if it is possible to install it as part of the SETUP.exe. I am using lv8.6 and the "Installer " under the "Build Specifications" has no such options. This would be where I would expect it to be. Thank you. Van
(3,289 Views)
Since this question refers to LabVIEW and not to LabWindows/CVI you should post it to the correct forum board.
(3,285 Views)
