LabWindows/CVI
Third-party FPGA programming
I have an FPGA card from Mesa Electronics.  Can I use LabWindows to program this card, or does the FPGA module only work with NI FPGA?  Thanks.
(3,772 Views)
At this time, the LabVIEW FPGA Module can only program National Instruments boards. The only exception to this is an academic-only board.
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(3,755 Views)
In addition, you cannot use LabWindows to progam any FPGA products. You must use LabVIEW FPGA. There is a text-based host programming utility, however.
Rob K
(3,753 Views)
