LabWindows/CVI
Time/Date versus Temparature graph in LabWindows/CVI
I want display date and time in X -axis and Temparature in Y axis. How i can do above requirement in LabWindows/CVI?
(3,043 Views)
You could use "Lable strings" instead of normal values in the x axis, establishing an adapt relation between the shown date and the value on the X axis (seconds from start of the phenomenon, for example).
Hope this helps
Roberto
(3,043 Views)
I also think this is the fastest way to get a correct Time displayed in the graph. Here is a small example that demonstrates how to setup the String/Numeric value pairs to display time.
I Hope this helps.
Juan Carlos
N.I.
(3,043 Views)
