LabWindows/CVI
Time stamping the samples
 Hi all,
 I am using NI PCI-6251 daq card for acquiring analog signals and i am also writing the samples
of analog signals in a file. Can anyone tell me what i have to do for writing the time at which the sample
was acquired.
In short, i want to time stamp my each acquired sample. Please show me how to do this?
The resolution of time must be 10 usecs.
Any help will be greatly appreciated.
(2,963 Views)
On a 100 kS/sec acquisition it is often better to timestamp process start only, and rely on acquisition board capabilities to maintain a constant acquisition rate. This is the concept of waveform which can be passed e.g. to PlotWaveform to display it on a graph.
In case you want to examine a portion of the process, sample index * (1 / acquisition rate) gives you the time offset from acquisition start.
(2,953 Views)
