LabWindows/CVI
To Spencer
Thank you.But ai_async.prj is an asynchronous one.
If I need a synchronous one to achieve high sample rate, do I need extra
hardware in windows2000?
(2,929 Views)
Hello Shen,
The other example that Spencer referenced (ai_acq.prj example) will be a synchronous analog input example that will allow you to acquire at a higher rate with hardware timing. It uses the ScanOp function which is a synchronous function.
I hope this helps.
Todd D.
NI Applications Engineer
(2,929 Views)
