LabWindows/CVI
Toolbar Custom Control Ring question
Hi.  This is probably a dumb question, but how do I add items to a ring (kRing) toolbar item when using the Toolbar Custom Control (toolbar.fp) in CVI 2010?  Thanks.
(3,519 Views)
Accepted by topic author tstanley
You can add your items by first getting the control ID of the toolbar item via the Toolbar_GetCtrlFromIndex or Toolbar_GetCtrlFromDescription functions, and then using InsertListItem to add your items to the ring.
Luis
(3,507 Views)
Interesting.  I take it that the toolbar items are actually just standard control types and once I have the toolbar's panelhandle and control ID I can manipulate the items as controls with the standard user interface library functions (within reason of course)?
In any case, thanks for the help.  That worked perfectly.
(3,504 Views)
