LabWindows/CVI
Toolbox Assertion Errors
The system has Windows XP. I developed an activeX server to monitor TestStand flags, which are located in the system tray. This application uses the system tray to attach all monitors; in addition, there is a main system tray icon for the application. I am using CVI 7.0 as ADE. My application works correctly in Windows 2K; however, it doesn't in Windows XP. The system gives me the following message: "The error was detecting in lime 13564 of the file 'toolbox.c'." I do not know if I have to use a specific version of the toolbox.c. The error appears when we put the mouse over the application system tray icons. I recompiled my applications on Windows XP, but it did not work neither.
(3,481 Views)
Hi Eduardo,
Not sure, but your issue may be related to a registry key that is in XP, but not in 2k. Take a look at this thread.
Jeremy L.
Jeremy L.
(3,480 Views)
We have the same problem. On Win 2k everything is Ok, but on Win XP this Assert dialog shows up 4x a day. This is very annoying, especially on our production test systems. Is there a solution available for CVI7.0 / 7.1 ?
Best regards Thomas Fechtel, Hella KG
(3,344 Views)
Hi Thomas,
Do these threads help?
Cheers,
David Goldberg
Software R&D
(3,295 Views)
