LabWindows/CVI
Toolslib Word Report Instrument driver
I have the CVI 8.0 full development system installed and I want to use the Word Report driver for a new project I have in the near future. I decided to look at the example code today to get some experience using the library. It compiles just fine but I can't get it to link. It is apparently missing a .lib or .obj file somewhere and can't resolve the function names for this driver.
I looked for a library or object file in the driver directory and there were two object files called word97.obj and word2000.obj I added these to the project and it still won't link.
So what am I missing? Is there something I need to do to configure something on the ActiveX side?
Anyone?
(And yes, NI reports works beautifully but I can't save anything generated by it...)
Martin Fredrickson
Test Engineer
Northrop Grumman
Advanced Systems and Products
San Diego, CA 92128
(3,550 Views)
OK, I figured out where I went wrong.
Instead of adding the wordreport.fp file to the libraries, I needed to use it as an instrument driver. Problem solved.
Martin Fredrickson
Test Engineer
Northrop Grumman
San Diego, CA 92128
(3,535 Views)
