LabWindows/CVI
Tooltip mouseover event?
Hi all.
I'm displaying a status word as binary flags and trying to use the tooltip to decode the actual statuses. What I really need is some sort of mouseover event to calculate the tooltip on the fly. At the moment I'm using a rather tedious right click routine which is a long way short of slick. Thanks.
Status example
(4,828 Views)
I had a similar task, see here, and ended up in suggesting a new feature. Maybe you want to support this suggestion by giving it a kudos.
(4,824 Views)
Kudos all round then, although I note there seems to have been little reponse to what seems like a fairly simple mod over the last year or so. Thanks for your reply.
(4,821 Views)
You are right, time scales in the Idea Exchange are long... but hope dies last Smiley Wink
(4,817 Views)
