LabWindows/CVI
Tracking
Hi. I am building a robot and i am using parallel port to control it. The thing is i don't know how to track an object by using usb web-cam. Is there anyone can help me?????
(3,675 Views)
Probably you will need NI-IMAQ, for a start see here
(3,671 Views)
First thanks for your respond. I have already have it and it works. I can see images by using web cam. But how can i track an object which i will choose from the web cam window?
(3,655 Views)
This is just a camera driver that allows you to capture an image.  If you want to do any sort of image processing you will need Vision Development Module.  It sounds like some sort of pattern matching is what you will want to do.
Justin D.
(3,611 Views)
