LabWindows/CVI
Traditional DAQ -- Digital Waveform
I have Ni 6534. I am using "Read Dig Port" to read data. I want to show the digital waveform.How can I convert my current  format to the Digital Waveform format. My card supports only Traditional DAQ
(3,418 Views)
Here you can find an example how to plot digital data:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=C992FFC758951004E034080020E74861&p_...
If you are using CVI 8.0 or later, you could of couse use the built in Digital Graph as well.
Hope this helps!
(3,397 Views)
Thank you.Yes i think the example would be helpful & also i have found a Logic-Analyzer example for LabView environment.
Regards
(3,392 Views)
