LabWindows/CVI
Trangular waveform generation
We have PXI6711 and the waveform editor . We would like generate arbitrory trangular wave form with frequency 1.5/15khz at the rate of 10Hz. Pl find the attachment for the wave form requirement . Pl provide me the solution whether this is possible using PXI 6711 and the waveform editor .
Thanks In advancce
Sharanu
(3,213 Views)
You should have no trouble using the waveform editor and the pxi-6711 to output the analog waveform. I suggest you use the waveform editor to build that particular waveform and save it to a file. You can than use CVI to read the data from the file and output it. The analog output limit on the 6711 is 1000 k S/s.
(3,213 Views)
