LabWindows/CVI
Transfer Function with CVI 5.0
Dear Sir/Madam,
Let me first introduce myself. I am a Telecomunication Engineering student
from Spain workimg on a project based on Labwindows/CVI and the data adquisitionscard
PCI 6024E.
In this project I have to calculate the transfer function of a network
under test, and I would like to display the amplitude and phase in frecuency.
I just got to display the window spectrum so far (mainlobe and sidelobes),
and I would like to display the amplitude and phase spectrum as a Bode Diagram.
To develope this project I am using the Advanced Analisys Library and the
function Transfer Function.
I would really appreciate your help in the following matters:
a) How can I display the transfer function as a Bode Diagram?
b) What
stimulus do I have to generate for a band width (2KHz)?
c) What window do I have to use?
I am grateful for your attencion and I will be working forward to hearing
from you.
I would also appreciate if you could send me an application example.
Yours sincerely .
Carlos Gutierrez Castellano
e-mail:carlos_guti@wanadoo.es
Message 1 of 1
(3,056 Views)
