LabWindows/CVI
Transferring structure through activeX server to client
Need to transfer a custom object from server to client. Both server &
client developed in CVI. Any examples on how to do it.
vishi
(3,729 Views)
An interesting discussion about trasferring structures can be found here
It relates to communication via TCP/IP, but it can be useful as a framework for you to develop your application.
Roberto Bozzolo
(3,729 Views)
What I've done before (but not in CVI) is to transfer the structure as a SAFEARRAY of unsigned char, packaged into a VARIANT. CVI has some nice functions in the ActiveX library to achieve this.
Martin
Martin
Certified CVI Developer
(3,729 Views)
Transferring through TCP/IP is much easier than doing through ActiveX .
Just send the structure as bunch of bytes, nothing more. Thanks for the
link anyways.
vishi
> href="http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=50650000000800000...
> Roberto Bozzolo
(3,729 Views)
Vishi,
I know it is possible to pass user defined data types through a VARIANT, however my ActiveX knowledge is not profound enough to know how to do it.
There are 2 things that I sugest you look at: first here is a link to a msdn document that talks about passing structures by packaging then in a SAFEARRAY; they don't flatten the data to chars, but they pass a pointer within the SAFEARRAY.
http://www.microsoft.com/msj/0696/activex0696.aspx
The second thing to look at is at VARIANTARG, I'm not very familiar with this but I believe this structure allows you to pass a pointer to any user defined data as a VARIANT.
I hope this advice can help you.
Juan Carlos
N.I.
(3,729 Views)
vishi
JuanCarlos wrote:
> Vishi,
> how to do it.
> Regards,
> Juan Carlos
> N.I.
(3,729 Views)
