LabWindows/CVI
Tree Attribute
How can I uncheck all checked data of a tree? The tree has the ATTR_SHOW_MARKS attribute setted;
Is it possible to do it with a simple command?
Thank you in advance.
Message Edited by Oliveira on 09-26-2007 03:18 PM
(3,726 Views)
Not as far as I am aware. I use code like:
    int nItems, indx;
    GetNumListItems(pMain,MAIN_DATASETS,&nItems);
    for (indx=0;indx<nItems;indx++)
     SetTreeItemAttribute(pMain,MAIN_DATASETS,indx,ATTR_MARK_STATE,VAL_MARK_OFF);
but if anyone has a better solution I'd like to see it.
Martin
Certified CVI Developer
(3,706 Views)
Martin,
You don't have to iterate through all the items. The SetTreeItemAttribute function allows you to pass VAL_ALL_OBJECTS as the index.
Luis
(3,701 Views)
That's handy 🙂
Thanks for the tip.
Martin
(3,677 Views)
