LabWindows/CVI
Trigger based finite data acquisition
Hi all,
I need to acquire a finite amount of samples at each rising edge of the signal trigger coming from PFI0 of a PXI 6115 board.
This is the code:
int checkError(int code)
    if(DAQmxFailed(code)){
        char err_string[2048];
        qDebug() << code;
        DAQmxGetErrorString (code, err_string, ERR_STRING_MAX_SIZE);
        qDebug() << QString(err_string);
    return code;
TaskHandle handle;
int daqmx_ret = DAQmxCreateTask("MYTASK",&handle);
checkError(daqmx_ret);
daqmx_ret = DAQmxCreateAIVoltageChan(handle,
                                           "PXI1Slot4/ai0",
                                           "",                      //Name to assign to channel
                                           DAQmx_Val_Cfg_Default,   //Terminal config
                                           -10,
                                           10,
                                           DAQmx_Val_Volts,         //Units
                                           nullptr);
daqmx_ret = DAQmxCfgSampClkTiming(handle,
                                        1000000,
                                        DAQmx_Val_Rising,
                                        DAQmx_Val_FiniteSamps,
                                        10000);
daqmx_ret = DAQmxCfgDigEdgeStartTrig(handle,"/PXI1Slot4/PFI0",DAQmx_Val_Rising);
daqmx_ret = DAQmxSetStartTrigRetriggerable(handle,1);
But I received the following error when the DAQmxSetStartTrigRetriggerable function was invoked:
-200452 "Specified property is not supported by the device or is not applicable to the task."
What's the error?
(2,539 Views)
can this thread give you some useful ideas, maybe?
Alessia
(2,503 Views)
