LabWindows/CVI
Tutorial
I am going through the Tutorial for LabWindows/CVI and I cannot find template.uir??  Where can I get this template.uir file?
Mike
TechnologyKitchen.com
(3,613 Views)
Hi mshoemak,
This sounds like something you have to create. Open up LabWindows/CVI, select New Project and when this project opens, go to File->New->User Interface File. This will open up untitled.uir. If you are still running into trouble, please specify which tutorial you are working with as well as which versions of CVI. Good luck!
Jackie
DAQ Product Marketing Engineer
(3,596 Views)
