LabWindows/CVI
Type define of IniText
I would like to use "inifile.fp" driver to IO files.
I noticed that their is "IniText"struct which is
defined as following in inifile.h:
typedef struct IniStructForwardReferenceTag *IniText;
However, I can not find the defination of IniStructForwardReferenceTag
yinyz
(5,123 Views)
struct IniStructForwardReferenceTag is declared in ...\CVI\toolslib\toolbox\inifile.c
(5,117 Views)
Thank you. I've got it, but I am still puzzling about the meaning of
IniStructForwardReferenceTag's member. Acctually, I found that there
is not enough help attached to CVI's help menu, Especiall for those
.fp function.
Is it possible for me to find some docs and samples about .fp function?
Yinyz
(5,105 Views)
Hello Yinyz,
For an example on how to read/write ini files in CVI, I would suggest taking a look at the ini shipping example located at /samples/toolbox/ini.prj.
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
(5,084 Views)
