LabWindows/CVI
UDP Library, UDPRead packet loss
Good morning
Thank you jr_2005 for the bunch of suggestions.
Using a static array, without malloc(), did not improve performance.
What is SDK (Xilinx Software Developement Kit?)? I tried to use just one call (i can predict the size the buffer has to offer, it is always the same. so i don't need to allocate it dynamically) of UDPRead: size = UDPRead(channel, msg, 1458, UDP_DO_NOT_WAIT, &srcPort, srcAddr);
The result was even worse. Only 64 or 73 packets were read.
I run the debug mode, yes. When the packets were sent i wait a few seconds and stop debugging to look at the value of the counter variable. I tried to run in release mode but it is a bit difficult. I have to output the counter variable, but there is no end in the programm. So i used printf every time a packet gets counted:
  if(size == 1458)
   counter++;
   printf("%d\n", counter);
Now only 7 or 8 packets were recognized. I know, printf on every count is not a smart solution. Any suggestions how to output the data in release mode more efficient?
In the CVI help there isn't mentioned such a ProcessUDPEvents() function. In the sample codes the RunUserInterface(); is used.
I have read the parts of socket/network programming in a german openbook about C (http://openbook.galileocomputing.de/c_von_a_bis_z/025_c_netzwerkprogrammierung_001.htm#mja8101c6e0e4...)
But first i tried to make use of CVI UDP Library. I haven't yet written my own udp socket functions.
edit:
I have no experience with threads. But in this example no other tasks are to perform, so all the computing power can be used for handling the UDP event
Greetings Florian
Message 11 of 11
(1,116 Views)
