LabWindows/CVI
UIR Incomaptibility V5.0 to V5.5
Dear LabWindowers
Recently I had to modify a LabW program originally build with V5.0 with the
actual LabW V5.5 version. It contained UIRs, which also had to be adapted.
It was impossible to do this task straightaway. I had to rewrite all UIRs
(several hours work), because the original UIRs (V5.0) refused to work properly
- references to UIR functions incorrect.
Is this a known problem in LabW?
Ewald
(3,083 Views)
We have not had this problem reported for CVI 5.5. I have used hundreds of
projects built in CVI 5.0 in CVI 5.5. There must be something specific with
your project or UIR file that caused the problem. CVI 5.5 should be able
to use any project from CVI 5.0. You may want to contact our support engineers
and let them look at your project to see if we can find out why you experienced
the problem. You can submit questions via e-mail to NI at http://www.ni.com/ask/.
Best Regards,
Chris Matthews
Measurement Studio Support Manager
"Ewald" wrote:
>>Dear LabWindowers>>Recently I had to modify a LabW program originally build
with V5.0 with the>actual LabW V5.5 version. It contained UIRs, which also
had to be adapted.>>>It was impossible to d
to rewrite all UIRs>(several hours work), because the original UIRs (V5.0)
refused to work properly>- references to UIR functions incorrect. >>Is this
a known problem in LabW?>>Thanks>Ewald
(3,083 Views)
