LabWindows/CVI
UIR unable to open
I have create a uir in labwindows/cvi 2017 but i am unable to open the application  in  ni labwindows cvi 8.5
(1,232 Views)
That's not surprising: cvi 8.5 is targeted to Windows Vista at last, while 2017 starts from Win7 on!
If your sentence means that you have created an executable in CVI2017 and cannot run it on a different PC with CVI8.5 intalled then you may want to try creating a distribution for your application so that the correct runtime and additional software is installed on the target macine, but you may run into some constraint if the target machine OS is too old.
(1,218 Views)
Is this question somewhat related to this other one of yours? Then you have your response there.
(1,215 Views)
