LabWindows/CVI
UIconv.exe ATTR_SHOW_INCDEC_ARROWS bug, and more.
Hi all
As far as I can see, UIconv.exe does not include the ATTR_SHOW_INCDEC_ARROWS for numeric controls even if value is different from default, so the generated controls show always the inc/dec arrows.
Can someone confirm this?
[Edit]
Another bug happens when the error checking is disabled (-noErrChecking in command line).
The converter leaves behind the unused "error" variable and unreachable code chunks that trigger compiler warnings when building the project.
Carlo A.
Megaris
(1,393 Views)
Can you elaborate?
(1,257 Views)
Harvery91, I wrote that message five months ago.
I was struggling with CVI utility "UIconv.exe" (aka "UI to Code Converter") using it from the command line (nothing changes using the GUI, anyway).
The two bugs I encountered are described clearly, IMHO.
If I was too short for you, please ask for specific question.
And I've not checked if there are improvements in CVI "2020 f1" release.
Carlo A.
Megaris
(1,247 Views)
