LabWindows/CVI
USB write problem in bulk pipe in usb raw
  hello;
I want to write 8 byte to a usb raw device,but the write() must been call back many times for write the data to device,I dont know what is wrong with my programe,the usb raw have one interrupt in -pipe and one bulk out --pipe ,i will use the out bulk pipe to change the I/0 of device.i hope you can help me.
#include <ansi_c.h>
#include <visa.h>
#include <cvirte.h>
#include <userint.h>
#include "USB.h"
static int panelHandle;
static ViSession defaultRM;
static ViSession instr;
static unsigned char buffer[100];
static   int i;
static ViUInt16     RcCount;
static ViUInt8    RcCounteel[9];
static ViStatus     STATUS;
static ViSession    USB_INICIO;
static ViString identificador_usb = "USB0::0x10C4::0x0000::NI-VISA-0::RAW";
static ViFindList   findList;
static ViUInt32     numInstrs;
static char instrDescriptor[256];
static ViSession    USB_FIND;
static  ViUInt8   Swrite[8]={1,0,1,1,1,1,0,0};
int main (int argc, char *argv[])
/* Open Default RM */
 if (InitCVIRTE (0, argv, 0) == 0)
  return -1; /* out of memory */
 if ((panelHandle = LoadPanel (0, "USB.uir", PANEL)) < 0)
  return -1;
 DisplayPanel (panelHandle);
 RunUserInterface ();
 DiscardPanel (panelHandle);
 return 0;
int CVICALLBACK senddate(int panel, int control, int event,
  void *callbackData, int eventData1, int eventData2)
    ViEventType  tipoEvento=-5;
       ViEvent      evento;
          switch (event)
    case EVENT_COMMIT:
         STATUS = viOpenDefaultRM (&USB_INICIO);
   if(STATUS != VI_SUCCESS)
   {break;
   STATUS = viFindRsrc (USB_INICIO, identificador_usb, &findList, &numInstrs, instrDescriptor);
    MessagePopup("ATEN??O","N?o foi possivel abrir a  viFindRsrc");
    QuitUserInterface (0);    };
   STATUS = viOpen (USB_INICIO, &instrDescriptor[0], VI_NULL, VI_NULL, &USB_FIND);
   STATUS = viSetAttribute (USB_FIND, VI_ATTR_TMO_VALUE, 2000);
    viSetAttribute(USB_FIND,VI_ATTR_MAX_QUEUE_LENGTH,50);
    MessagePopup("ATEN??O","N?o foi possivel abrir a VI_ATTR_MAX_QUEUE_LENGTH ");
    QuitUserInterface (0); // for?a o fechamento do programa
     STATUS=viWrite (USB_FIND, Swrite, 8, VI_NULL);
    MessagePopup("ATEN??O","N?o foi possivel abrir a viWrite ");
   break;
  return 0;
int CVICALLBACK Quite (int panel, int control, int event,
 switch (event)
  case EVENT_COMMIT:
   STATUS = viClose (USB_FIND);
   STATUS = viClose (USB_INICIO);
   break;
 return 0;
Message 1 of 1
(3,234 Views)
