LabWindows/CVI
USING INTERRRUPTS
    I m currently working on a program to acquire data from a headtracker(ascension technologies) via rs-232. However i m having errors in compiling the program on labwindows. I have used the source code provided by ascension technologies in C in the program. This source sode runs well with borland cThe source code has functions like serial isr, read data from the device.
My questions are
- Can i use interrupts(IRQ4,IRQ3)that we use in c in labwindows? Do they need to be modified in labwindows?
- Some of the interrupt structure in the C code provided by ascension technologies is linked to file dos.h which i think is not recognised by win 2K
-I m having errors in compiling on statements like
 setvect(COM1INTERRUPT-comport,serialisr);    Error :missing prototype
void interrupt far serialisr(void);                             Error: missing prototype
void interrupt far (*oldserialintvect)(void); /* old serial interrupt vector */
(3,226 Views)
Your legacy code has its own interrupt service routine and interacts with the com port at a very low level.
WIn2K, NT, and XP all use a "Hardware Abstraction Layer" that purposely prevents interacting with the hardware at that level.
There are third party products that attempt to emulate the DOS / Win9X environment for interrupt driven legacy code, but we've had bad luck with them.  They seem to have a hard time emulating the IRQ functionality.  They kindof work, but interrupt response is very slow.
You could re-write to use the native Win32 serial drivers (and use the CVI serial library which runs on top of the native serial driver).  The equivalent of interrupt response to a serial port using the NI rs-232 library is to install a com port callback, which will "interrupt" with a callback on specified serial port input conditions (e.g. a character in the in queue).  With a modern PC it's likely you can match the interrupt driven performance of your legacy system unless maybe you're using a custom bit rate that's very high.
Some of the NI serial cards (843X) use the new NI serial driver, which I believe is a kernel mode (i.e. low level, below the HAL) driver that supports hyperthreading and multi-processing.  We've had serial ports that simply won't work if hyper-threading or multi-processing is enabled.
Hayes
(3,207 Views)
