LabWindows/CVI
Uir file formats
Is there a way to find out which format an UIR file has. The most interesting UIR formats for us are:
  • LabWindows/CVI 7.1 User Interface (*.uir)
  • LabWindows/CVI 8.0–8.1 User Interface (*.uir)
  • LabWindows/CVI 8.5–9.0 User Interface (*.uir)
Jan
(5,320 Views)
Good question.
I develop for CVI Linux 8.0 using the Windows 8.5 version and I keep
forgetting to use [Save as] instead of Ctrl-S. If I could test it in my
makefile, it would save on useless invalid commits.
Guillaume Dargaud
http://www.gdargaud.net/
(5,264 Views)
Although there's no good way to find out what format a .UIR file was saved in, we are making a change in CVI whereby it will remember the last format that you saved it in and use that by default. This way you won't have to remember to use "Save As" each time.
I apologize for the inconvenience up until now.
Luis
NI
(5,257 Views)
> in, we
> you saved
> "Save As" each time. I apologize for the inconvenience up
> until
> now. LuisNI
Thanks, I appreciate... although I'd rather have the Linux version able to
load 8.5 UIR files... Hint, hint...
PS: I won't try the 9.0 version for now because of lack of Linux support,
but has the UIR format changed again ?
Guillaume Dargaud
"You know how people are. They only recognize greatness when some
authority confirms it." - Calvin.
(5,230 Views)
It has not changed between 8.5 and 9.0.
Luis
(5,215 Views)
