LabWindows/CVI
Unable to get into Debug Mode
When using LabWindows/CVI version 6 I am having a problem where I can't run in debug mode.
The program was working correctly for a while but now when I select RUN from the menu, the "Debug Project" menu item is greyed out.  There must be some setting that I accidently changed to cause this problem.
John Bessire
(3,540 Views)
John,
Make sure that you didn't inadvertently change the target type to be a DLL. Check Build>>Target Type.
If your project is supposed to be a DLL, then you need to have something entered in Run>>Select External Process.
Luis
NI
(3,532 Views)
Luis,
Thanks for the help and I got it working.
The Target Type was blank and I am using a DLL.  After changing the Target Type to  TestStand the debug is now working.
John Bessire
(3,507 Views)
