LabWindows/CVI
Unable to load DLL
I have an .exe prj residing in different directory from a DLL prj that I am trying to call. I keep getting build error: Unable To Locate Component... *.dll not found. In my .exe prj I have added the *dll.h file and the *.lib file as well from the directory from which dll resides. What's wrong??
(4,053 Views)
Hello
You need to verify that your dll is in one of the following folders.
-The directory where the executable module for the current process is located.
-The current directory.
-The Windows system directory. The GetSystemDirectory function retrieves the path of this directory.
-The Windows directory. The GetWindowsDirectory function retrieves the path of this directory.
-The directories listed in the PATH environment variable.
Windows is responsible for loading the dll for the exe at run-time. You will get a missing dll error when you attempt to run the exe and Windows is unable to find the dll it requires. A missing dll would not cause an error during compile time
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(4,053 Views)
In my case I don't need any dll's. I'm just trying to debug a simple tester c file. It can't locate ".dll" (nothing before the period).
Why is it looking for a blank dll?
Could and would reinstall the driver for the instrument I'm writing the module for, but there is no driver.
(3,452 Views)
